Ga door naar hoofdinhoud
Fluke 77 Series III Range/Hold Buttons Replacement
Wat je nodig hebt
  1. Fluke 77 Series III Range/Hold Buttons Replacement, Front Panel: stap 1, afbeelding 1 van 1
    • Be sure any test leads are out and the multimeter is off before opening the device.
    • Turn the multimeter so it is display side down.
    • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
  2. Fluke 77 Series III Range/Hold Buttons Replacement: stap 2, afbeelding 1 van 1
    • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
  3. Fluke 77 Series III Range/Hold Buttons Replacement: stap 3, afbeelding 1 van 2 Fluke 77 Series III Range/Hold Buttons Replacement: stap 3, afbeelding 2 van 2
    • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
    • Pry the front panel from the back panel at the seam.
    • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
  4. Fluke 77 Series III Range/Hold Buttons Replacement, Range/Hold Buttons: stap 4, afbeelding 1 van 2 Fluke 77 Series III Range/Hold Buttons Replacement, Range/Hold Buttons: stap 4, afbeelding 2 van 2
    • Locate the rubber range and hold buttons in the internal assembly. These are found just below the LCD screen on the left hand side.
    • The buttons are attached so they will come out of the multimeter as a single part.
    • Remove the rubber range and hold button part with your thumb and forefinger.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jessica Bombardier Shaw
1.012 Reputatie
7 handleidingen geschreven
Cal Poly, Team 2-10, Amido Winter 2014 Lid van Cal Poly, Team 2-10, Amido Winter 2014
CPSU-AMIDO-W14S2G10
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 870
