Ga door naar hoofdinhoud
Fluke 77 Series III Battery Replacement
Wat je nodig hebt
  1. Fluke 77 Series III Battery Replacement, Front Panel: stap 1, afbeelding 1 van 1
    • Be sure any test leads are out and the multimeter is off before opening the device.
    • Turn the multimeter so it is display side down.
    • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
  2. Fluke 77 Series III Battery Replacement: stap 2, afbeelding 1 van 1
    • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
  3. Fluke 77 Series III Battery Replacement: stap 3, afbeelding 1 van 2 Fluke 77 Series III Battery Replacement: stap 3, afbeelding 2 van 2
    • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
    • Pry the front panel from the back panel at the seam.
    • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
  4. Fluke 77 Series III Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Fluke 77 Series III Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • When doing this next step, make sure to remove the battery slowly, so you don't damage the wires connecting the battery to the device.
    • Locate the 9V battery in the lower right corner of the device.
    • Pull the battery out of its terminal.
  5. Fluke 77 Series III Battery Replacement: stap 5, afbeelding 1 van 2 Fluke 77 Series III Battery Replacement: stap 5, afbeelding 2 van 2
    • Only pull on the metal snaps and battery. Pulling the cords may damage them.
    • Detach the two metal snaps from the battery.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Jessica Bombardier Shaw
1.012 Reputatie
7 handleidingen geschreven
Cal Poly, Team 2-10, Amido Winter 2014 Lid van Cal Poly, Team 2-10, Amido Winter 2014
CPSU-AMIDO-W14S2G10
4 Leden
10 handleidingen geschreven
Één opmerking
Easy to understand and all went well!
petruskewichw - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 113
Altijd: 19,105
