Ga door naar hoofdinhoud
Floor Pump O-Rings Replacement
Wat je nodig hebt
  1. Floor Pump O-Rings Replacement, O-Rings: stap 1, afbeelding 1 van 1
    • Detach the hose from its holder.
  2. Floor Pump O-Rings Replacement: stap 2, afbeelding 1 van 2 Floor Pump O-Rings Replacement: stap 2, afbeelding 2 van 2
    • Hold the base of the pump steady and twist the barrel counter-clockwise by hand until it completely unthreads.
    • If you are having troubles stabilizing the base and twisting the barrel, try standing on the base and using both hands to loosen the barrel.
    • Lift the barrel off the base.
    • When removing the barrel, be sure not to lose the bump stop O-ring. It may stick to the pump base, may be stuck inside the barrel, or may fall out when you remove the barrel.
  3. Floor Pump O-Rings Replacement: stap 3, afbeelding 1 van 1
    • Lift the pump handle until the top cap is expsoed
  4. Floor Pump O-Rings Replacement: stap 4, afbeelding 1 van 3 Floor Pump O-Rings Replacement: stap 4, afbeelding 2 van 3 Floor Pump O-Rings Replacement: stap 4, afbeelding 3 van 3
    • Place the ends of needle nose pliers into the top cap holes and turn counter-clockwise until the cap is loose.
    • Finish removing the top cap by hand.
    • Pull the pump plunger out of the barrel.
  5. Floor Pump O-Rings Replacement: stap 5, afbeelding 1 van 2 Floor Pump O-Rings Replacement: stap 5, afbeelding 2 van 2
    • Use a small flathead screwdriver to remove the plunger O-ring.
    • Use the screwdriver to remove the upper bump stop O-ring.
    • Install new O-rings.
    • Be careful not to over-stretch or cut the O-rings if you are using the screwdriver to install them.
  6. Floor Pump O-Rings Replacement: stap 6, afbeelding 1 van 2 Floor Pump O-Rings Replacement: stap 6, afbeelding 2 van 2
    • Remove the lower bump stop O-ring from the pump base.
    • Remove and replace the base O-ring.
  7. Floor Pump O-Rings Replacement: stap 7, afbeelding 1 van 3 Floor Pump O-Rings Replacement: stap 7, afbeelding 2 van 3 Floor Pump O-Rings Replacement: stap 7, afbeelding 3 van 3
    • Insert the tips of needle nose pliers into the base cap holes and turn it counter-clockwise until it completely unthreads.
    • Remove the base cap from the pump base.
    • Remove and replace the base cap O-ring.
    • Re-assemble the pump using these instructions backwards.
    • Don't forget to set a new bump stop O-ring on top of the pump base before re-installing the pump barrel.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
iRobot
1 Reputatie
636 handleidingen geschreven
Één opmerking
I was looking for ideas on how to “make" an O- ring. It can't be that difficult. I'll update when the plan comes together.?
RBizerka - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 17
Altijd: 6,279
