Ga door naar hoofdinhoud
Floor Pump Gauge Replacement
Wat je nodig hebt
  1. Floor Pump Gauge Replacement, Removing the Gauge Cover: stap 1, afbeelding 1 van 2 Floor Pump Gauge Replacement, Removing the Gauge Cover: stap 1, afbeelding 2 van 2
    • Using a flat head screwdriver, pry up an edge of the gauge cover.
    • Remove the gauge cover.
  2. Floor Pump Gauge Replacement, Removing the Gauge Face Plate and Internals: stap 2, afbeelding 1 van 3 Floor Pump Gauge Replacement, Removing the Gauge Face Plate and Internals: stap 2, afbeelding 2 van 3 Floor Pump Gauge Replacement, Removing the Gauge Face Plate and Internals: stap 2, afbeelding 3 van 3
    • No parts from the old gauge will be re-used, so there is no need to attempt to preserve the parts. However, be careful not to damage the gauge housing.
    • Pry up a corner of the gauge face plate.
    • Use pliers to pull off the gauge face plate.
    • Be careful not to cut yourself when prying off the face plate, as the edges are sharp.
    • Use pliers to pry out the internal gauge mechanics.
  3. Floor Pump Gauge Replacement, Removing the Old Gauge: stap 3, afbeelding 1 van 2 Floor Pump Gauge Replacement, Removing the Old Gauge: stap 3, afbeelding 2 van 2
    • Using pliers, grip the exposed brass piece and unthread the gauge by rotating it counter-clockwise.
    • Pull the gauge out of its housing.
  4. Floor Pump Gauge Replacement, Replacing the Gauge O-rings: stap 4, afbeelding 1 van 2 Floor Pump Gauge Replacement, Replacing the Gauge O-rings: stap 4, afbeelding 2 van 2
    • Remove the O-ring at the bottom of the threaded hole.
    • Place a new O-ring into the hole.
  5. Floor Pump Gauge Replacement, Applying Threadlocker: stap 5, afbeelding 1 van 1
    • Apply medium-strength Loctite (green, 290) to the threads on the new gauge.
    • Apply a thin layer, but make sure it covers all the threads.
  6. Floor Pump Gauge Replacement, Installing the New Gauge: stap 6, afbeelding 1 van 3 Floor Pump Gauge Replacement, Installing the New Gauge: stap 6, afbeelding 2 van 3 Floor Pump Gauge Replacement, Installing the New Gauge: stap 6, afbeelding 3 van 3
    • Thread the new gauge into the floor pump by turning it clockwise in its housing.
    • Thread the gauge until it is snug and the BAR/psi markings are aligned with the pump body.
    • Gauge performance will not be affected by its position, so long as it is snug.
    • Allow at least 30 minutes for the thread locker to set.
    • Test the pump to its highest rated pressure and listen for leaks. If you can hear leaks from the gauge, tighten it.
Eindstreep
iRobot
1 Reputatie
636 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 2,841
