Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use the utility scissors to remove the tip of the broken line strap.
Position one 8-inch zip tie underneath the strap line.
Head end of the zip tie.
Tail end of the zip tie.
Fold the zip tie so that the head end is on top of the line strap.
Insert the tail end through the head end to make a loop.
Tighten the loop by pulling on the tail end of the zip tie.
Pass the metal flat washer through the second 8-inch zip tie.
4.8mm metal flat washer.
Pass the tail end through the hole on the bottom of the flip-flop.
Pass the tail end through the loop of the first zip tie.
Return the tail end back through the hole.
Pass the tail end into the 4.8mm metal flat washer.
Push the 4.8mm metal flat washer inside the hole of the flip-flop.
Adjust the length of the zip tie to create a snug fit between your toes.
Push the loop of the tail into the hole.
Pull on the tail end until you're satisfied with the length.
Turn the flip-flip over occasionally to check the length of the toe piece as needed.
Length of toe piece.
Cut off about a 1-inch piece of heavy duty duct tape.
Wrap the 1-inch piece of heavy duty duct tape tightly around the toe piece of the flip-flop.
6 andere personen hebben deze handleiding voltooid.
2 opmerkingen
my faovert flip flops were riped by a cazey man at the swimming pool i saw him waht to do
Awesome. Thank you!
