Ga door naar hoofdinhoud
Flip-Flop Line Strap Replacement
Wat je nodig hebt
  1. Flip-Flop Line Strap Replacement, Line Strap: stap 1, afbeelding 1 van 1
    • Use the utility scissors to remove the tip of the broken line strap.
    • Try to remove as much of the broken tip as possible.
  2. Flip-Flop Line Strap Replacement: stap 2, afbeelding 1 van 1
    • Position one 8-inch zip tie underneath the strap line.
    • Head end of the zip tie.
    • Tail end of the zip tie.
    • You can use any color zip tie to match the color of your flip-flop.
    • Zip ties can be purchased from stores such as Walmart, Ace Hardware, and the Dollar Tree.
  3. Flip-Flop Line Strap Replacement: stap 3, afbeelding 1 van 1
    • Fold the zip tie so that the head end is on top of the line strap.
  4. Flip-Flop Line Strap Replacement: stap 4, afbeelding 1 van 1
    • Insert the tail end through the head end to make a loop.
  5. Flip-Flop Line Strap Replacement: stap 5, afbeelding 1 van 1
    • Tighten the loop by pulling on the tail end of the zip tie.
    • Make the loop approximately a half-inch.
  6. Flip-Flop Line Strap Replacement: stap 6, afbeelding 1 van 1
    • Cut off the extra zip tie material.
  7. Flip-Flop Line Strap Replacement: stap 7, afbeelding 1 van 1
    • Pass the metal flat washer through the second 8-inch zip tie.
    • 4.8mm metal flat washer.
  8. Flip-Flop Line Strap Replacement: stap 8, afbeelding 1 van 1
    • Pass the tail end through the hole on the bottom of the flip-flop.
  9. Flip-Flop Line Strap Replacement: stap 9, afbeelding 1 van 1
    • Pass the tail end through the loop of the first zip tie.
  10. Flip-Flop Line Strap Replacement: stap 10, afbeelding 1 van 2 Flip-Flop Line Strap Replacement: stap 10, afbeelding 2 van 2
    • Return the tail end back through the hole.
    • Pass the tail end into the 4.8mm metal flat washer.
    • Turn the flip-flop on its side for a better view.
  11. Flip-Flop Line Strap Replacement: stap 11, afbeelding 1 van 1
    • Push the 4.8mm metal flat washer inside the hole of the flip-flop.
  12. Flip-Flop Line Strap Replacement: stap 12, afbeelding 1 van 1
    • Insert the tail end into the head end.
  13. Flip-Flop Line Strap Replacement: stap 13, afbeelding 1 van 2 Flip-Flop Line Strap Replacement: stap 13, afbeelding 2 van 2
    • Adjust the length of the zip tie to create a snug fit between your toes.
    • Push the loop of the tail into the hole.
    • Pull on the tail end until you're satisfied with the length.
    • Turn the flip-flip over occasionally to check the length of the toe piece as needed.
    • Length of toe piece.
    • This step might take some trial and error.
  14. Flip-Flop Line Strap Replacement: stap 14, afbeelding 1 van 1
    • Push the head end into the hole of the flip-flop.
    • It's okay if the head end does not fit perfectly inside the hole. It will eventually fit deeper into the hole from walking.
  15. Flip-Flop Line Strap Replacement: stap 15, afbeelding 1 van 1
  16. Flip-Flop Line Strap Replacement: stap 16, afbeelding 1 van 1
    • Cut off about a 1-inch piece of heavy duty duct tape.
    • You can use any color heavy duty duct tape to match the color of your flip-flop.
  17. Flip-Flop Line Strap Replacement: stap 17, afbeelding 1 van 1
    • Wrap the 1-inch piece of heavy duty duct tape tightly around the toe piece of the flip-flop.
    • If you don't have heavy duty duct tape, use two pieces of regular duct tape.
Conclusie
Your flip-flops are now restored! If you decide that you don't want them, please consider donating them to a local charity organization.
6 andere personen hebben deze handleiding voltooid.
Dominique Hall
505 Reputatie
1 Handleiding geschreven
2Gids Commentaar
my faovert flip flops were riped by a cazey man at the swimming pool i saw him waht to do
Toby Robinson - Antwoord
Awesome. Thank you!
Windogalaz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 119
Altijd: 27,775
