Inleiding
This guide will walk you through how to remove and replace the circuit board should your device be broken or malfunctioning. You will need a # 1 Phillips Head screwdriver, a plastic opening tool and tweezers. This easy process should take no more than 15 minutes.
Wat je nodig hebt
Unlock the battery cover by sliding the switch to the unlock position.
Één andere persoon heeft deze handleiding voltooid.
