Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove metal sticker under the LCD screen with a spudger.
Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
Open battery door. This can be done by gently depressing and sliding the battery down downward.
Use the spudger to separate outer shells.
The spudger must be inserted between the shell halves to pry the edges apart.
Slowly work around the outside to separate the halves.
Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
Disconnect the USB port cable from the back side of the circuit board.
Slide out the battery contacts.
Battery contacts
Slot where battery contacts were located
With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
Flip over the circuit board and unlock the two black tabs on the ribbon connector by sliding them upwards.
Één andere persoon heeft deze handleiding voltooid.
