Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
If the casing of your device becomes damaged and needs replaced we have provided you helpful guides to do so. This should be an easy fix and with just a few tools the casing will be removed!
Wat je nodig hebt
With the plastic opening tool, remove labels from the Flip Mino HD. 2 small black screws should appear.
With the Phillips Screwdriver 000, unscrew the 2 screws and set aside in a safe place.
With the plastic opening tool, gently pry the front casing away from the device by carefully running the tool around each edge and lifting.
Once case is loose, flip up and over the device. Note that casing is still connected to the device.
Using tweezers, pull connecting strip to disconnect it from its socket on the logic board.
Één andere persoon heeft deze handleiding voltooid.
