Inleiding
Officially the Flashforge Finder 2 only supports Flashforge's FlashPrint slicer but it is possible to use it with other slicers. There are both community plugins and data to configure an arbitrary slicer (both at your own risk)
Flashforge Finder printer integration and GXWriter are UltiMaker Cura plugins made with the Finder in mind, but also work well with the Finder 2
They add all the necessary information about the printer, including different quality profiles, and support for the proprietary .GX file format
Bed: Rectangular, X/Y/Z140/140/140 mm, origin at center
G-code flavor: Marlin
Printhead: X/Y min -20/-10 mm, X/Y max 37/55 mm
Gantry height: 28 mm
Extruder: nozzle diameter 0.4 mm, filament diameter 1.75 mm
Start/End G-Code: there are different possibilities, see from Cura Integration plugin, from slicer-settings on GitHub, from Reddit, from Cracked the Code
Configuring Ultimaker Cura to Support the Flashforge Finder 3D Printer, Cracked the Code
ronoaldo/slicer-settings, GitHub
FlashForge Finder profile for Cura 4, r/Flashforge
