Ga door naar hoofdinhoud
Flash Motherboard
Wat je nodig hebt
  1. Flash Motherboard, Front and Back Covers: stap 1, afbeelding 1 van 3 Flash Motherboard, Front and Back Covers: stap 1, afbeelding 2 van 3 Flash Motherboard, Front and Back Covers: stap 1, afbeelding 3 van 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
    Vraag FixBot
    Voeg opmerking toe
  2. Flash Motherboard: stap 2, afbeelding 1 van 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
    Vraag FixBot
    Voeg opmerking toe
  3. Flash Motherboard: stap 3, afbeelding 1 van 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Flash Motherboard: stap 4, afbeelding 1 van 2 Flash Motherboard: stap 4, afbeelding 2 van 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  5. Flash Motherboard: stap 5, afbeelding 1 van 1
    • The camera should look like this once the front cover is removed.
    Vraag FixBot
    Voeg opmerking toe
  6. Flash Motherboard: stap 6, afbeelding 1 van 3 Flash Motherboard: stap 6, afbeelding 2 van 3 Flash Motherboard: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
    Vraag FixBot
    Voeg opmerking toe
  7. Flash Motherboard: stap 7, afbeelding 1 van 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
    Vraag FixBot
    Voeg opmerking toe
  8. Flash Motherboard, Flash Motherboard: stap 8, afbeelding 1 van 1
    • Turn to the front of the camera.
    • Find the flash motherboard located behind the flash assembly on the top right.
    Vraag FixBot
    Voeg opmerking toe
  9. Flash Motherboard: stap 9, afbeelding 1 van 1
    • Use a soldering iron and a desoldering wick to disconnect the wires from the marked locations.
    • Once the cables are disconnected, you are now ready to install a new motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Jakub
134 Reputatie
2 handleidingen geschreven
Cal Poly, Team 8-6, Regan Spring 2011 Lid van Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Leden
22 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 40
Altijd: 4,481
