Ga door naar hoofdinhoud
Fixing the Error Code 165-6596
Wat je nodig hebt
  1. Fixing the Error Code 165-6596, Removing the stylus and battery lid: stap 1, afbeelding 1 van 2 Fixing the Error Code 165-6596, Removing the stylus and battery lid: stap 1, afbeelding 2 van 2
    • Remove the stylus. This in order to correctly remove the back cover
    • Unscrew the battery lid with the P00 Philps Screwdriver.
  2. Fixing the Error Code 165-6596, Removing the battery: stap 2, afbeelding 1 van 1
    • After removing the lid, carefully remove the cable connecting the battery to the motherboard and lift up the battery
  3. Fixing the Error Code 165-6596, Removing the back cover: stap 3, afbeelding 1 van 1
    • Remove the screw covers with the pick and use the Tri-wing Screwdriver to unscrew the remaining screws around the GamePad.
    • Lift up the back cover
    • Lift up gently, as the rumble motor is attached
  4. Fixing the Error Code 165-6596, Reseating the NFC board: stap 4, afbeelding 1 van 1
    • I have put a circle around the correct placement of the NFC board. This is how it should look like.
    • If the NFC board is detached, gently reseat it back to where it was.
    • If the NFC board seated correctly, gently remove and gently reseat it.
Conclusie
To reassemble your device, follow these instructions from Step 3 in reverse order. If the problem persists (even after multiple attempts), it might be time to order a replacement part.
ChrisLord9
307 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 72
Altijd: 2,949
