Ga door naar hoofdinhoud
Fixing a Wobbly Armrest on the VonRacer Gaming Chair
Wat je nodig hebt
  1. Fixing a Wobbly Armrest on the VonRacer Gaming Chair, Fixing a Wobbly Armrest on the VonRacer Gaming Chair: stap 1, afbeelding 1 van 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair, Fixing a Wobbly Armrest on the VonRacer Gaming Chair: stap 1, afbeelding 2 van 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair, Fixing a Wobbly Armrest on the VonRacer Gaming Chair: stap 1, afbeelding 3 van 3
    • To be able to reach the bolts on the bottom of the seat in an easily accessible manner, you should pull out the leg rest and recline the seat all the way back.
    • After doing so, put the chair on its side.
    • This is recommended to be able to have an easier time removing the screws.
  2. Fixing a Wobbly Armrest on the VonRacer Gaming Chair: stap 2, afbeelding 1 van 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: stap 2, afbeelding 2 van 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: stap 2, afbeelding 3 van 3
    • Remove the two 25 mm arm rest bolts with an M8 hex screwdriver.
    • Remove the arm rest.
  3. Fixing a Wobbly Armrest on the VonRacer Gaming Chair: stap 3, afbeelding 1 van 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: stap 3, afbeelding 2 van 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: stap 3, afbeelding 3 van 3
    • Tighten the three screws on the arm rest, one for the elbow joint and two for the arm rest cushion, with a Phillips #1 screwdriver.
    • Give the arm rest a shake to ensure there is no wobble in the two joints.
  4. Fixing a Wobbly Armrest on the VonRacer Gaming Chair: stap 4, afbeelding 1 van 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: stap 4, afbeelding 2 van 3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: stap 4, afbeelding 3 van 3
    • Align the arm rest with the two screw holes on the bottom of the seat.
    • Replace the two 25 mm M8 hex screws to secure the arm rest.
    • Be sure to sufficiently tighten these screws to eliminate any wobble.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Abdullahi Hassan
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 101
Altijd: 13,822
