Ga door naar hoofdinhoud
Fixing a Refrigerator Door Seal
Wat je nodig hebt
  1. Fixing a Refrigerator Door Seal, Fixing a Refrigerator Door Seal: stap 1, afbeelding 1 van 3 Fixing a Refrigerator Door Seal, Fixing a Refrigerator Door Seal: stap 1, afbeelding 2 van 3 Fixing a Refrigerator Door Seal, Fixing a Refrigerator Door Seal: stap 1, afbeelding 3 van 3
    • Grab a Phillips Head Screw Driver
    • Lift up the door seal and locate the screws underneath that hold the seal in place. Loosen the screws to where they are pretty loose, but not out of their hole.
    • Note To save energy, you can turn off your refrigerator before proceeding to steps 2-6.
  2. Fixing a Refrigerator Door Seal: stap 2, afbeelding 1 van 3 Fixing a Refrigerator Door Seal: stap 2, afbeelding 2 van 3 Fixing a Refrigerator Door Seal: stap 2, afbeelding 3 van 3
    • After all the screws are loose, the door seal should slide off fairly easy. Slowly remove the door seal with your hands by peeling it off the seal's shell.
  3. Fixing a Refrigerator Door Seal: stap 3, afbeelding 1 van 3 Fixing a Refrigerator Door Seal: stap 3, afbeelding 2 van 3 Fixing a Refrigerator Door Seal: stap 3, afbeelding 3 van 3
    • Thoroughly wash the door seal in Soap and Water
    • Using a paper towel (or regular towel), dry the seal.
    • Note If your seal has cracks in it, you will need to replace it. If this is the case, skip this step.
  4. Fixing a Refrigerator Door Seal: stap 4, afbeelding 1 van 2 Fixing a Refrigerator Door Seal: stap 4, afbeelding 2 van 2
    • On the side that connects to the refrigerator unit, apply a thin layer of silicon grease. This will improve functionality as well as prevent the seal from cracking in the future.
  5. Fixing a Refrigerator Door Seal: stap 5, afbeelding 1 van 3 Fixing a Refrigerator Door Seal: stap 5, afbeelding 2 van 3 Fixing a Refrigerator Door Seal: stap 5, afbeelding 3 van 3
    • To reattach the seal,feed the back of the seal behind the white frame.
    • It is easiest to do this by starting at any corner and completing one side at a time.
  6. Fixing a Refrigerator Door Seal: stap 6, afbeelding 1 van 3 Fixing a Refrigerator Door Seal: stap 6, afbeelding 2 van 3 Fixing a Refrigerator Door Seal: stap 6, afbeelding 3 van 3
    • Make sure the white shell is holding the seal in place on all sides.
    • Tighten all of the screws back in place.
Conclusie
Your refrigerator should now stay shut properly, and the seal should be tightly secured in place. To assure proper functionality, check every once in awhile to make sure the seal is firmly in place.
59 andere personen hebben deze handleiding voltooid.
Curtis Rosol
1.883 Reputatie
1 Handleiding geschreven
Cal Poly, Team 30-5, Green Spring 2015 Lid van Cal Poly, Team 30-5, Green Spring 2015
CPSU-GREEN-S15S30G5
5 Leden
31 handleidingen geschreven
11 opmerkingen
Love that you show how to fix on a mini fridge! #CollegeLife Thanks for this :)
tcarle1191 - Antwoord
How can I fix the seals on chest fridge.
Ramon Espinoza - Antwoord
Thank you for such a great article with the pictures, it is really helpful! I have just looked at my fridge door, lookes like i know how to detach the seal, but… i am afraid i won´t be able to put it back again…)))
AngiGi - Antwoord
buy a new fridge - i wood- support american union workers
dkp50 - Antwoord
How much should the GE repairman charge for this repair? My mother-in-law was told it’ll cost her between $250-$275. I think that’s too much due to the cost of the seal. Does the labor cost account for the extra $200?
Raymond Frazier - Antwoord
CLICK on the link here to help us engineering students to solve Fridge door problems!! https://docs.google.com/forms/d/e/1FAIpQ...
Brock Erekson - Antwoord
DON'T PUT VASELINE. I've ruined 2 fridges with this, now they're constantly running. You'll need silicon grease. This article is right. If it ain't broke, don't fix it, and &&^& the Vaseline guys
Mait Oliver Hellat - Antwoord
The seal was indeed damaged, but the door is unbalanced. Next repair for my 30 year old fridge.
Thanks for the great guidance.
Pamela Johnson - Antwoord
Buy used support the little guy who refurbish
Leslie Newman - Antwoord
Thanku so much. It was really helpful. Got my problem fixed by ur advice.
ISRAR UL HAQ - Antwoord
How to fix a fridge or freezer seal: The easy way!
Use Duct tape to hold the door closed while you push (gently crushing the door seal) the door closed as hard as you can easily do. Leave the duct tape on for about 24 hours.
In most cases this will cause the door seal to re-level itself and seal better for a long time to come.
Generally, if a dollar bill placed between the door and the fridge comes out EASILY it means that that spot is not sealing well.
Glenn N. Davis - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 21
Afgelopen 7 dagen: 164
Afgelopen 30 dagen: 761
Altijd: 311,355
