Ga door naar hoofdinhoud
Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler
Wat je nodig hebt
  1. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 1, afbeelding 1 van 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 1, afbeelding 2 van 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 1, afbeelding 3 van 3
    • Turn your label-maker on its face. Using your thumb, press in and then upward on the fastener located on the side of your device.
  2. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 2, afbeelding 1 van 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 2, afbeelding 2 van 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 2, afbeelding 3 van 3
    • Remove the batteries from your device.
  3. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 3, afbeelding 1 van 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 3, afbeelding 2 van 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 3, afbeelding 3 van 3
    • Using a plastic opening tool from your iFixit tool kit, leverage the label cartridge out of your device.
  4. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 4, afbeelding 1 van 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 4, afbeelding 2 van 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 4, afbeelding 3 van 3
    • Press the label paper back into alignment with the small holders on the right side of the label cartridge.
  5. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 5, afbeelding 1 van 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 5, afbeelding 2 van 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 5, afbeelding 3 van 3
    • Place the label cartridge and batteries back into your device. Refasten the bottom case of the label-maker.
  6. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 6, afbeelding 1 van 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 6, afbeelding 2 van 3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: stap 6, afbeelding 3 van 3
    • Well done! You have successfully corrected the paper-jam in your Brother PT-90 Label-Maker.
Conclusie
Kaitlyn Abrams
1 Reputatie
1 Handleiding geschreven
University of Maine, Team 2-1, Diaz Fall 2016 Lid van University of Maine, Team 2-1, Diaz Fall 2016
UMAINE-DIAZ-F16S2G1
3 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 814
