Ga door naar hoofdinhoud
Fixed Gear Bike Chainring Replacement
Wat je nodig hebt
  1. Fixed Gear Bike Chainring Replacement, Chainring: stap 1, afbeelding 1 van 2 Fixed Gear Bike Chainring Replacement, Chainring: stap 1, afbeelding 2 van 2
    • Slightly loosen the two rear nuts with a 15 mm wrench to give the chain slack.
    • Remove the chain from the worn out chain ring.
  2. Fixed Gear Bike Chainring Replacement: stap 2, afbeelding 1 van 2 Fixed Gear Bike Chainring Replacement: stap 2, afbeelding 2 van 2
    • Undo all five bolts attached to the crank arm with a hex tool.
  3. Fixed Gear Bike Chainring Replacement: stap 3, afbeelding 1 van 2 Fixed Gear Bike Chainring Replacement: stap 3, afbeelding 2 van 2
    • Take the chain ring off through the crank arm of the pedal and swap the chainring of your choice.
    • Keep all five bolts in the same area to prevent losing them.
    • When bolts appear to be rusty, I recommend replacing them with a new set of bolts for the longevity of the drivetrain.
  4. Fixed Gear Bike Chainring Replacement: stap 4, afbeelding 1 van 1
    • Line up the chainring’s hole to the crankset and tighten all five bolts to hold the chainring in place.
  5. Fixed Gear Bike Chainring Replacement: stap 5, afbeelding 1 van 1
    • Lastly, attach the chain back to the new chainring.
    • Before tightening the two rear nuts back together, ensure the wheel is centered and not touching the rear bike frame.
Eindstreep
aljndro__
121 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Lid van CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 24
Altijd: 254
