Ga door naar hoofdinhoud
Inleiding
This is a way that may be able to fix the problem that makecab.exe runs for a long time, slowing down the computer. There are also many articles about makecab.exe that you can google.
Time the problem occurred to me: May 2018 on my windows 7 home 64bit.
  1. Find CBS log files folder. The folder usually contains a .log file under 2 GB, and some .cab files.
    • Find CBS log files folder. The folder usually contains a .log file under 2 GB, and some .cab files.
  2. Delete, or move away if you want to keep the logs, any .log files larger than 2 GB in the CBS folder. If makecab.exe is currently running and processing the log files, you may need to end it through Task manager.
    • Delete, or move away if you want to keep the logs, any .log files larger than 2 GB in the CBS folder.
    • If makecab.exe is currently running and processing the log files, you may need to end it through Task manager.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Somnic
105 Reputatie
1 Handleiding geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 267
