Ga door naar hoofdinhoud
Fix a Loose Mounting Dream MD2462 TV Wall Mount
Wat je nodig hebt
  1. Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 1, afbeelding 1 van 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 1, afbeelding 2 van 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 1, afbeelding 3 van 3
    • Remove the two M4x5mm bolts on the back of the TV plate using a Phillips #00 screwdriver.
    • Unplug the TV cables before removing the TV from the wall.
  2. Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 2, afbeelding 1 van 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 2, afbeelding 2 van 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 2, afbeelding 3 van 3
    • Remove the three lag bolts from the wall mount by using a 13mm open-end wrench.
    • If it is too loose, it can just be pulled out.
  3. Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 3, afbeelding 1 van 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 3, afbeelding 2 van 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 3, afbeelding 3 van 3
    • Fill the holes where the screws were secured using drywall spackle.
  4. Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 4, afbeelding 1 van 1
    • Locate the wooden studs on the wall using a stud finder or knock on the wall to see if the stud is behind the wall.
  5. Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 5, afbeelding 1 van 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 5, afbeelding 2 van 3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 5, afbeelding 3 van 3
    • Use a pencil to mark three holes on the wall.
    • Use a 3/8-inch drill bit to drill three holes at the marked positions.
    • Secure the wall mount into the wooden studs using new screws or bolts.
    • Ensure that all the screws are firmly secured to the wooden stud.
  6. Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 6, afbeelding 1 van 2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 6, afbeelding 2 van 2
    • Test the firmness of the TV wall mount by gently pushing it up and down.
  7. Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 7, afbeelding 1 van 2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 7, afbeelding 2 van 2
    • Gently replace the TV back on the wall mount.
  8. Fix a Loose Mounting Dream MD2462 TV Wall Mount: stap 8, afbeelding 1 van 1
    • Make sure the TV is secure and well-centered on the wall mount using a spirit level gauge to confirm the inclination.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Emmanuel Emedeke
184 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 53
Altijd: 5,048
