Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Fix Game Disc Tray wont open., Fix Game Disc Tray wont open.: stap 1, afbeelding 1 van 1
    • Manually eject the CD/DVD Drive
    What is that metal tool called?
    sexy boy - Antwoord
  2. Fix Game Disc Tray wont open.: stap 2, afbeelding 1 van 1
    • There will be a gap in the middle of the CD/DVD tray. You will see 2 pulleys with a rubber belt. Use tweezers to carefully take the belt out.
  3. Fix Game Disc Tray wont open.: stap 3, afbeelding 1 van 2 Fix Game Disc Tray wont open.: stap 3, afbeelding 2 van 2
    • Take a Damp paper towel and clean any dust and dirt off of the rubber belt.
  4. Fix Game Disc Tray wont open.: stap 4, afbeelding 1 van 1
    • Using the tweezers again carefully put the rubber belt back in. I have found it easier to get it around the big pulley first then on the small pulley.
    • At this point turn the system on and test it. I have done this on several system that the drive just would not open and it has solved the issues.
Conclusie
Enjoy your Original Xbox again! Please sent me a message if you have any questions about the steps.
10 andere personen hebben deze handleiding voltooid.
Matt Weatherly
1.043 Reputatie
2 handleidingen geschreven
Één commentaar
In my case cleaning the rubber band didn’t help - it has gotten too old and hard. I replaced it with the cheapest band from assorted set of rubber bands from the nearest supermarket, and it worked like a charm. Also the whole set cost me less than a dollar, so you may want to try that first before ordering overpriced "xbox" rubber bands from ebay.
Rathori - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 153
Altijd: 4,811
