Ga door naar hoofdinhoud
Fitting Ski Bindings to a New Pair of Boots
Wat je nodig hebt
  1. Fitting Ski Bindings to a New Pair of Boots, Fitting Ski Bindings to a New Pair of Boots: stap 1, afbeelding 1 van 1
    • Locate the boot size (in millimeters) on the bottom of the boot.
    • If the boot size is not on the bottom, check the inner or outer sides of the heel.
    • In our case, the size is 316mm. However, this may not be the case for everyone.
  2. Fitting Ski Bindings to a New Pair of Boots: stap 2, afbeelding 1 van 3 Fitting Ski Bindings to a New Pair of Boots: stap 2, afbeelding 2 van 3 Fitting Ski Bindings to a New Pair of Boots: stap 2, afbeelding 3 van 3
    • Place your ski on a flat surface with the ski bindings facing up.
    • Locate the lever on the side of the heel piece of the binding.
    • Lift and hold the lever in the upright position.
  3. Fitting Ski Bindings to a New Pair of Boots: stap 3, afbeelding 1 van 3 Fitting Ski Bindings to a New Pair of Boots: stap 3, afbeelding 2 van 3 Fitting Ski Bindings to a New Pair of Boots: stap 3, afbeelding 3 van 3
    • With the lever raised, slide the heel piece until the markers point to the correct range of the boot size.
    • Given the boot size in this guide is 316mm, the correct range for this ski boot is 311mm - 318mm. This may not be the case for everyone.
  4. Fitting Ski Bindings to a New Pair of Boots: stap 4, afbeelding 1 van 3 Fitting Ski Bindings to a New Pair of Boots: stap 4, afbeelding 2 van 3 Fitting Ski Bindings to a New Pair of Boots: stap 4, afbeelding 3 van 3
    • Locate the lever on the toe piece of the binding.
  5. Fitting Ski Bindings to a New Pair of Boots: stap 5, afbeelding 1 van 3 Fitting Ski Bindings to a New Pair of Boots: stap 5, afbeelding 2 van 3 Fitting Ski Bindings to a New Pair of Boots: stap 5, afbeelding 3 van 3
    • With the lever raised, slide the toe piece until the markers point to the correct boot size range.
    • Given the boot size in this guide is 316mm, the correct range for this ski boot is 315mm - 322mm. This may not be the case for everyone.
  6. Fitting Ski Bindings to a New Pair of Boots: stap 6, afbeelding 1 van 3 Fitting Ski Bindings to a New Pair of Boots: stap 6, afbeelding 2 van 3 Fitting Ski Bindings to a New Pair of Boots: stap 6, afbeelding 3 van 3
    • Insert the toe of the boot into the toe piece of the binding.
    • Push down on the boot until the boot clips into the binding. If needed, you can lift the lever on the heel piece to facilitate the procedure.
  7. Fitting Ski Bindings to a New Pair of Boots: stap 7, afbeelding 1 van 2 Fitting Ski Bindings to a New Pair of Boots: stap 7, afbeelding 2 van 2
    • Insert the screwdriver in the front of the toe piece.
    • Loosen the screw until the toe bar moves backwards.
    • You should be able to fit a piece of paper between the bottom of the boot and the toe bar.
  8. Fitting Ski Bindings to a New Pair of Boots: stap 8, afbeelding 1 van 2 Fitting Ski Bindings to a New Pair of Boots: stap 8, afbeelding 2 van 2
    • Insert a piece of paper between the bottom of the boot and the toe bar.
    • Tighten the screw at the front of the toe piece until there is resistance when pulling the paper out.
    • You should be able to pull the paper out without it ripping but not push it back in.
    • Over-tightening of the toe bar can be dangerous. Practice caution and take your time.
  9. Fitting Ski Bindings to a New Pair of Boots: stap 9, afbeelding 1 van 2 Fitting Ski Bindings to a New Pair of Boots: stap 9, afbeelding 2 van 2
    • Adjust the DIN setting on the toe piece to your personalized setting by tightening or loosening the screw on the side of the bindings.
    • Look at the window on the top of the toe piece to see the current DIN setting.
    • Skiing with a DIN setting that is too high can be dangerous, because the bidding won't be activated if the ski is subject to high strains. Use caution to not over-tighten the screw. On the contrary, a low value will cause undesired activations of the binding, which can be dangerous, too.
  10. Fitting Ski Bindings to a New Pair of Boots: stap 10, afbeelding 1 van 3 Fitting Ski Bindings to a New Pair of Boots: stap 10, afbeelding 2 van 3 Fitting Ski Bindings to a New Pair of Boots: stap 10, afbeelding 3 van 3
    • Repeat step 9 but on the heel piece.
    • Adjust the DIN setting on the heel piece by tightening or loosening the screw on the back.
    • Look at the window on the top of the heel piece to see the current DIN setting.
    • Skiing with a DIN setting that is too high can be dangerous. Use caution to not over-tighten the screw.
Conclusie
Repeat this guide on the other ski and you’re ready to go!
3 andere personen hebben deze handleiding voltooid.
Veronica Contreras
217 Reputatie
1 Handleiding geschreven
UC Davis, Team S1-G3, Andersen Winter 2020 Lid van UC Davis, Team S1-G3, Andersen Winter 2020
UCD-ANDERSEN-W20S1G3
4 Leden
5 handleidingen geschreven
4 opmerkingen
Super Anleitung, vielen Dank. Das erspart mir eine Fahrt quer durch die Stadt zum Sportgeschäft!
Joerg Schnur - Antwoord
Kürzer und klarer geht es nicht. Alle horizontalen und vertikalen Fragen sind beantwortet. Danke
Andreas Rothe - Antwoord
Sehr gute Anleitung auch für Anfänger.
Tuzzer 2 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 93
Afgelopen 30 dagen: 753
Altijd: 69,897
