Ga door naar hoofdinhoud
Fitbit Charge HR Vibration Motor Replacement
Wat je nodig hebt
  1. Fitbit Charge HR Vibration Motor Replacement, Vibration Motor: stap 1, afbeelding 1 van 1
    • Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
    • Remove the back cover from the device.
  2. Fitbit Charge HR Vibration Motor Replacement: stap 2, afbeelding 1 van 3 Fitbit Charge HR Vibration Motor Replacement: stap 2, afbeelding 2 van 3 Fitbit Charge HR Vibration Motor Replacement: stap 2, afbeelding 3 van 3
    • Remove the two 2.9 mm Torx screws holding the circuit board in place.
    • Carefully pry the board out using an opening tool.
  3. Fitbit Charge HR Vibration Motor Replacement: stap 3, afbeelding 1 van 1
    • Remove the motherboard assembly from the device by gently lifting.
  4. Fitbit Charge HR Vibration Motor Replacement: stap 4, afbeelding 1 van 2 Fitbit Charge HR Vibration Motor Replacement: stap 4, afbeelding 2 van 2
    • Locate the vibration motor on the motherboard.
    • Desolder the red and black wires connected to the motherboard from the vibration motor.
    • Red wire is located closer to the outside. Black wire is closer to the inside of the motherboard.
    • Replace with new vibration motor.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 427
