Ga door naar hoofdinhoud
Fitbit Alta HR Battery Replacement
Wat je nodig hebt
  1. Fitbit Alta HR Battery Replacement, Remove straps: stap 1, afbeelding 1 van 2 Fitbit Alta HR Battery Replacement, Remove straps: stap 1, afbeelding 2 van 2
    • Push in the clip and slide off the strap from each side.
  2. Fitbit Alta HR Battery Replacement, Remove front cover: stap 2, afbeelding 1 van 1
    • Use a spudger to remove the front cover.
  3. Fitbit Alta HR Battery Replacement, Lift display: stap 3, afbeelding 1 van 1
    • Use a spudger to lift the display.
  4. Fitbit Alta HR Battery Replacement, Disconnect heart rate monitor: stap 4, afbeelding 1 van 1
    • Use a spudger to disconnect the cable that connects the heart rate monitor to the motherboard.
  5. Fitbit Alta HR Battery Replacement, Remove screws from motherboard: stap 5, afbeelding 1 van 1
    • Use a hex 0.7 screwdriver to remove the screws from the motherboard.
  6. Fitbit Alta HR Battery Replacement, Lift motherboard: stap 6, afbeelding 1 van 2 Fitbit Alta HR Battery Replacement, Lift motherboard: stap 6, afbeelding 2 van 2
    • Use a spudger to lift the motherboard.
  7. Fitbit Alta HR Battery Replacement, Lift battery and remove innards: stap 7, afbeelding 1 van 1
    • Use a spudger to lift the battery.
    • When the battery is lifted, the connected components (display, motherboard, battery) will come out.
    • Use a soldering iron to desolder the two battery contacts from the motherboard.
    • Ensure positive and negative wires are in the correct positions. There are + and – signs on the motherboard. Red is positive. Black is negative.
    • Use a soldering iron and lead-free solder to solder the new battery to the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Wendy Sato
229 Reputatie
1 Handleiding geschreven
Één opmerking
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 84
Altijd: 1,873
