Wat je nodig hebt
We'll be changing the oil and filter on my JDM-import 1999 Honda Odyssey with the 2.3L four-cylinder engine
Thankfully this car has a centre lift point at the front of the subframe at the tow-hook
I just used the normal pinch welds to put the jack-stands under
Position your drain pan, the drain bolt faces towards the rear of the oilpan
On this 1999 Odyssey it was a 23mm drain bolt
One of the hardest parts of this procedure
Honda put the oil filter mounting on the back of the engine block under the intake manifold
You have to reach past the subframe, exhaust, and axle
I like to use oil-filter pliers, but there are a few different tools that can be used
Check to make sure the gasket came off with the old filter and did not get left behind on the block
I used a JS Asakashi C-307J, (made in Japan)
I can order them shipped from Singapore cheaper then I can buy locally from Repco or Supercheap here in New Zealand
Oil up the gasket on the new filter
Clean the mounting plate on the block with your rags
If you've not already, put the drain bolt back in
Tighten the new oil filter 3/4 of a turn after it touches the block
Tighten the drain bolt without breaking it off :)
Clean around the filter and bolt with a rag so you can see any leaks
Remove your cardboard and tools
Lift the car again from the centre lift point with your hydraulic jack
Pull the jack-stands out from each side
Carefully lower the car to the ground, leveling it for filling
In the photo, the red circle is the oil fill point, and the yellow circle is the dipstick
I used Nulon 10W-40 full synthetic
I needed about 4.5L or so to fill
I like to use a stubby wide-mouth funnel
Pour large oil bottles sideways to reduce the blub-blub effect
Run the engine for about 10 seconds to fill up the filter and oil galleys
Turn the engine off and check for leaks
Check the level using the dipstick and a rag again, it should have gone down a bit due to the oil filter filling up
Top up the level to the upper range of the dipstick
Servicing done!
Servicing done!
Één andere persoon heeft deze handleiding voltooid.
