Inleiding
I just got this camera and was interested on seeing what was inside because I couldn’t find anything on the Internet, I struggled to get my jimmy into the casing but I finally got it and I applied force with my hands to pull the screen side off, it took more effort than expected and when it came off so did the ribbon cable connector attached to the screen, please go slow with this as the cables are thin and fragile
Wat je nodig hebt
I found it easiest to insert my jimmy into the side opposite of the keychain hook
Gently pull off the battery (the adhesive shouldn’t be too strong). Carefully pull the ribbon cable connecting the screen out after lifting the latch, disconnect the two screws, then you’re done
Go ever so slow
Één andere persoon heeft deze handleiding voltooid.
