Inleiding
Clean and remove damaged batteries that may have leaked caustic or harmful substances.
Wat je nodig hebt
Dab one end of the Q-tip into the vinegar solution.
Rub the inside and outside of the battery cartridge as well as the battery terminal with the Q-tip to remove any acid residue. Use as many Q-tips needed to remove the acid.
Once finished place the used Q-tip(s) inside the small bag with the battery and dispose of the two properly.
All done! Return the cartridge back into the center console and screw in the two 13mm screws.
Bijna klaar!
Eindstreep
