Ga door naar hoofdinhoud
Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW
Wat je nodig hebt
  1. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW, Filter Housing for GE Refrigerators: stap 1, afbeelding 1 van 1
    • Disconnect the electric plug from the wall.
  2. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: stap 2, afbeelding 1 van 1
    • Turn off or push down off water main valve from the wall.
  3. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: stap 3, afbeelding 1 van 3 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: stap 3, afbeelding 2 van 3 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: stap 3, afbeelding 3 van 3
    • Remove the back panel with 6 screws from the back panel using a 8 mm nut driver.
  4. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: stap 4, afbeelding 1 van 2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: stap 4, afbeelding 2 van 2
    • Disconnect the water supplied line from the refrigerator using two 13 mm open-end wrenches.
    • Use a little bucket to receive the water from the water lines.
  5. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: stap 5, afbeelding 1 van 1
    • Disconnect the water line from the water inlet valve using and open-end wrench size 15mm
  6. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: stap 6, afbeelding 1 van 2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: stap 6, afbeelding 2 van 2
    • Disconnect the water line cover removing 2 screws using a 7 mm nut driver.
    • Pull up the gum seal compound.
  7. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: stap 7, afbeelding 1 van 1
    • Push the left side of the filter cover and pull it straight out.
  8. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: stap 8, afbeelding 1 van 2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: stap 8, afbeelding 2 van 2
    • Remove the 2 screws on top of the housing using 7 mm nut driver.
    • Pull the housing and filter out slowly.
    • Remove the filter by turn it counterclockwise
Conclusie
Giancarlo Marruffo
2 Reputatie
1 Handleiding geschreven
Pasco Hernando, Team 5-1, Prince Fall 2016 Lid van Pasco Hernando, Team 5-1, Prince Fall 2016
PHSC-PRINCE-F16S5G1
1 Lid
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 2,090
