Ga door naar hoofdinhoud
Fender Frontman 15r Reverb Tank Replacement
Wat je nodig hebt
  1. Fender Frontman 15r Reverb Tank Replacement, Remove the Back Plate: stap 1, afbeelding 1 van 2 Fender Frontman 15r Reverb Tank Replacement, Remove the Back Plate: stap 1, afbeelding 2 van 2
    • Remove 6 Phillips screws securing the back plate.
    • Lift the back panel out of the amp.
    • Gently pry with a flathead screwdriver or other tool to release the back panel if it's stuck.
    • Be careful not to pull out the wires connected to the power converter.
  2. Fender Frontman 15r Reverb Tank Replacement, Free the Reverb Tank: stap 2, afbeelding 1 van 2 Fender Frontman 15r Reverb Tank Replacement, Free the Reverb Tank: stap 2, afbeelding 2 van 2
    • Saw the adhesive from in between the reverb tank and the cabinet until the reverb tank is released.
  3. Fender Frontman 15r Reverb Tank Replacement, Free the Connecting Wires: stap 3, afbeelding 1 van 1
    • Use wire cutters to remove the zip tie fastening the wires to the speaker.
  4. Fender Frontman 15r Reverb Tank Replacement, Disconnect Wires from Motherboard: stap 4, afbeelding 1 van 2 Fender Frontman 15r Reverb Tank Replacement, Disconnect Wires from Motherboard: stap 4, afbeelding 2 van 2
    • Unplug the wires leading from the reverb tank to the motherboard.
    • Notice they are plugged in where the motherboard is labeled "reverb only."
    What are these plug ends or leads called? Is there an RCA adapter/converter for them?
    John Ender - Antwoord
  5. Fender Frontman 15r Reverb Tank Replacement, Remove Reverb Tank: stap 5, afbeelding 1 van 1
    • Remove the reverb tank.
    what if I wanted to upgrade to gen 1 replacement like this one
    https://www.amplifiedparts.com/products/...
  6. Fender Frontman 15r Reverb Tank Replacement, Install New Reverb Tank: stap 6, afbeelding 1 van 1
    • Glue the new reverb tank into place following the directions provided with the glue or epoxy of your choice.
  7. Fender Frontman 15r Reverb Tank Replacement, Test the New Reverb Tank: stap 7, afbeelding 1 van 1
    • Reconnect the wires and test the new reverb tank ensuring the effect properly matches the knob setting.
Conclusie
Sam Omiotek
72.896 Reputatie
288 handleidingen geschreven
2 opmerkingen
I guess there is 2 versions of this amp the one in this video this version of the tank has 3 springs; this looks like 2…
Wonder which one was the newer version?
https://www.youtube.com/watch?v=o856fDGI...
Interesting! I wouldn’t know which is the newer version, but the one in the YouTube video does look like it has higher quality parts…
Sam Omiotek -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 40
Altijd: 2,338
