Inleiding
This guide walks the user through process to remove the gears and the shafts of the Fellowes T7CM paper shredder.
Wat je nodig hebt
Check to make sure the shredder is not plugged in to any electrical outlet.
Remove the shredder from the catch basket and place the silver side down on a flat surface.
Place the catch basket aside as you will not be needing it for the rest of the disassembly.
Flip the shredder silver side down and place on a flat even surface.
Remove the manufacturer's label in order to gain access to the hidden screw hole.
Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
Remove the three screws holding the internal case to the external case. The screw length is 18 mm and the head diameter is 5 mm.
Remove the internal case.
