Ga door naar hoofdinhoud
Fast Fix Shower Curtain Permanent Rod Replacement
Wat je nodig hebt
  1. Fast Fix Shower Curtain Permanent Rod Replacement, Shower Curtain Permanent Rod Replacement: stap 1, afbeelding 1 van 1
    • Use a measuring tape to measure the length of the rod in order to make sure the replacement is the same length.
  2. Fast Fix Shower Curtain Permanent Rod Replacement: stap 2, afbeelding 1 van 2 Fast Fix Shower Curtain Permanent Rod Replacement: stap 2, afbeelding 2 van 2
    • Using your flathead screwdriver or your screwdriver gun, loosen the screw by turning it counterclockwise.
  3. Fast Fix Shower Curtain Permanent Rod Replacement: stap 3, afbeelding 1 van 1
    • Remove the old rod as well as the brackets.
  4. Fast Fix Shower Curtain Permanent Rod Replacement: stap 4, afbeelding 1 van 1
    • Use disinfecting wipes to clean the area on the wall where the old brackets were.
  5. Fast Fix Shower Curtain Permanent Rod Replacement: stap 5, afbeelding 1 van 1
    • Grab your new shower curtain rod.
    • If preferred, hold your old shower curtain rod against your new one to make sure they are both the same size.
  6. Fast Fix Shower Curtain Permanent Rod Replacement: stap 6, afbeelding 1 van 2 Fast Fix Shower Curtain Permanent Rod Replacement: stap 6, afbeelding 2 van 2
    • Lastly, using your flat head screwdriver or screwdriver gun, rotate the screw clockwise to tighten the screw.
Conclusie
To reassemble your device, follow these instructions in reverse order
Één andere persoon heeft deze handleiding voltooid.
Abdul-Jabbar Mohamed
134 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 103
