Ga door naar hoofdinhoud
Inleiding
Have you ever had a lamp's pull chain break on you, leaving you with no way to turn it on? We understand. That's why we made this guide to fix the on/off switch on a perfectly good lamp! This guide will help you in repairing a snapped ball chain, allowing you to, once again, turn your lamp on and then off again.
Gereedschap
Geen gereedschap opgegeven.
Onderdelen
  1. Unplug the broken lamp and ensure you have all of the parts necessary for the repair.
    • Unplug the broken lamp and ensure you have all of the parts necessary for the repair.
  2. Remove the light bulb from the lamp. Remove the light bulb from the lamp.
    • Remove the light bulb from the lamp.
  3. Unscrew the lamp shade from the base by turning it counter-clockwise. Unscrew the lamp shade from the base by turning it counter-clockwise.
    • Unscrew the lamp shade from the base by turning it counter-clockwise.
  4. Gently pull the socket from the base to expose the broken chain section.
    • Gently pull the socket from the base to expose the broken chain section.
  5. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  6. Attach the chain connector to the extra chain. Attach the chain connector to the extra chain.
    • Attach the chain connector to the extra chain.
  7. Connect the chain with the chain connector to the broken chain on the lamp base. Connect the chain with the chain connector to the broken chain on the lamp base.
    • Connect the chain with the chain connector to the broken chain on the lamp base.
  8. Tilting the lamp in one hand, use your other hand to guide the chain into the hole that leads from inside of the socket to outside of the lamp. The chain will go down through this hole. The chain will go down through this hole.
    • Tilting the lamp in one hand, use your other hand to guide the chain into the hole that leads from inside of the socket to outside of the lamp.
    • The chain will go down through this hole.
  9. Gently push the socket back into place.
    • Gently push the socket back into place.
  10. Screw the lamp shade back onto the base of the lamp by turning it clockwise. Screw the lamp shade back onto the base of the lamp by turning it clockwise.
    • Screw the lamp shade back onto the base of the lamp by turning it clockwise.
  11. Replace the light bulb into the lamp socket.
    • Replace the light bulb into the lamp socket.
  12. Plug your lamp into an outlet and turn it on! You will pull down on the chain to do this.
    • Plug your lamp into an outlet and turn it on!
    • You will pull down on the chain to do this.
  13. Congratulations! You have fixed your lamp.
    • Congratulations! You have fixed your lamp.
Conclusie
Congratulations on fixing your lamp!
Anna Rill
214 Reputatie
1 Handleiding geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 1
Altijd: 66
