Ga door naar hoofdinhoud
Fast Fix Bathtub drain stopper Replacement
  1. Fast Fix Bathtub drain stopper Replacement, Bathtub drain stopper: stap 1, afbeelding 1 van 1
    • What do you need?
    • I went to my local Home Depot store and purchased the Danco EZ Drain Cover. The package included: the EZ Drain Cover and 2 gaskets
  2. Fast Fix Bathtub drain stopper Replacement: stap 2, afbeelding 1 van 1
    • Step 1
    • Remove the old stopper from the drain (my tub was without one when I bought the house)
  3. Fast Fix Bathtub drain stopper Replacement: stap 3, afbeelding 1 van 3 Fast Fix Bathtub drain stopper Replacement: stap 3, afbeelding 2 van 3 Fast Fix Bathtub drain stopper Replacement: stap 3, afbeelding 3 van 3
    • Step 2.
    • The gaskets come in two sizes, large and small. Determine which is the correct size. To do this, position the gasket into the groove of the stopper with the flange side in the upward position. Insert the stopper with the gasket in the drain. I tried the smaller one first and it was loose; then I tried the larger size & it fitted the drain perfectly
  4. Fast Fix Bathtub drain stopper Replacement: stap 4, afbeelding 1 van 1
    • Step 3
    • Test the stopper. Close the drain and fill the tub with water. Press down on top of the stopper to hold the water in the tub. To open the drain and release the water, press down on top of the stopper again
  5. Fast Fix Bathtub drain stopper Replacement: stap 5, afbeelding 1 van 1
    • Side Note
    • You may also use plumber's putty to seal the stopper. To use the plumber's putty, apply it around the under side of the stopper rim.  After it's applied, insert the stopper into the drain and press into place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bijgevoegde documenten
Fenita
148 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 109
