Ga door naar hoofdinhoud
Fairphone SIM Card Replacement
  1. Fairphone SIM Card Replacement, Back Cover: stap 1, afbeelding 1 van 3 Fairphone SIM Card Replacement, Back Cover: stap 1, afbeelding 2 van 3 Fairphone SIM Card Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • There is a small indentation in the side of the phone near the bottom of the back cover.
    • With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
  2. Fairphone SIM Card Replacement: stap 2, afbeelding 1 van 3 Fairphone SIM Card Replacement: stap 2, afbeelding 2 van 3 Fairphone SIM Card Replacement: stap 2, afbeelding 3 van 3
    • Slide the back cover down and remove it from the phone.
  3. Fairphone SIM Card Replacement, Battery: stap 3, afbeelding 1 van 3 Fairphone SIM Card Replacement, Battery: stap 3, afbeelding 2 van 3 Fairphone SIM Card Replacement, Battery: stap 3, afbeelding 3 van 3
    • There is a small indentation in the back of the phone just below the battery.
    • Use a fingernail in this indentation to push the battery toward the top of the phone
    • Pull the battery out away from the phone.
  4. Fairphone SIM Card Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery from your Fairphone.
  5. Fairphone SIM Card Replacement, SIM and MicroSD Card: stap 5, afbeelding 1 van 3 Fairphone SIM Card Replacement, SIM and MicroSD Card: stap 5, afbeelding 2 van 3 Fairphone SIM Card Replacement, SIM and MicroSD Card: stap 5, afbeelding 3 van 3
    • Use your finger to slide the SIM card straight down out of its tray.
    • Remove the SIM card from your Fairphone.
    • Repeat this procedure if you have a second SIM card.
    • Be sure to remove all SIM cards before servicing your phone.
  6. Fairphone SIM Card Replacement: stap 6, afbeelding 1 van 2 Fairphone SIM Card Replacement: stap 6, afbeelding 2 van 2
    • If you have a microSD card, use your finger to slide it straight out of its slot.
    • Remove the microSD card from your phone.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sam Goldheart
467.548 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
140 Leden
18.077 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 124
Altijd: 9,007
