Ga door naar hoofdinhoud
Fairphone 2 Rear Camera Module Replacement
Wat je nodig hebt
  1. Fairphone 2 Rear Camera Module Replacement, Slim Case: stap 1, afbeelding 1 van 3 Fairphone 2 Rear Camera Module Replacement, Slim Case: stap 1, afbeelding 2 van 3 Fairphone 2 Rear Camera Module Replacement, Slim Case: stap 1, afbeelding 3 van 3
    • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
    • Pull up the back part of the slim case to separate the small snap fit connections.
    • Remove the back part of the slim case.
  2. Fairphone 2 Rear Camera Module Replacement: stap 2, afbeelding 1 van 3 Fairphone 2 Rear Camera Module Replacement: stap 2, afbeelding 2 van 3 Fairphone 2 Rear Camera Module Replacement: stap 2, afbeelding 3 van 3
    • Get in between the front part of the slim case and the phone's body with your thumb nail.
    • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
  3. Fairphone 2 Rear Camera Module Replacement: stap 3, afbeelding 1 van 1
    • Remove the front part of the slim case.
  4. Fairphone 2 Rear Camera Module Replacement, Battery: stap 4, afbeelding 1 van 3 Fairphone 2 Rear Camera Module Replacement, Battery: stap 4, afbeelding 2 van 3 Fairphone 2 Rear Camera Module Replacement, Battery: stap 4, afbeelding 3 van 3
    • Push the battery toward the top of the phone.
    • Pull the battery out away from the phone.
  5. Fairphone 2 Rear Camera Module Replacement, Display Assembly: stap 5, afbeelding 1 van 3 Fairphone 2 Rear Camera Module Replacement, Display Assembly: stap 5, afbeelding 2 van 3 Fairphone 2 Rear Camera Module Replacement, Display Assembly: stap 5, afbeelding 3 van 3
    • After taking out the battery you can unlock the display assembly.
    • Flip the two blue switches to the inner position.
    • Slide the display assembly towards the bottom of the phone.
    • Another possible way of sliding the display assembly open.
  6. Fairphone 2 Rear Camera Module Replacement: stap 7, afbeelding 1 van 1
    • Take off the display assembly.
  7. Fairphone 2 Rear Camera Module Replacement, Rear Camera Module: stap 8, afbeelding 1 van 2 Fairphone 2 Rear Camera Module Replacement, Rear Camera Module: stap 8, afbeelding 2 van 2
    • Remove the three Phillips #0 screws of the module which are nicely marked by the blue circles.
    • Now the module should stand off a little bit due to the pogo pins underneath.
  8. Fairphone 2 Rear Camera Module Replacement: stap 9, afbeelding 1 van 1
    • Take out the whole module.
Conclusie
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
71 andere personen hebben deze handleiding voltooid.
Tobias Isakeit
129.593 Reputatie
189 handleidingen geschreven
Tobias Isakeit - Repairability Engineer Lid van Tobias Isakeit - Repairability Engineer
Business
1 Lid
1.145 handleidingen geschreven
23Gids Commentaar
Alles gut - hat wunderbar funktioniert, insbesondere dank des Videos für Schritt 4
Walter Strohschein - Antwoord
Heel snelle levering van mijn nieuwe camera!
Het was ons (mijn man) vast niet gelukt zonder de goede begeleidende filmpjes!
Betty Bol
Betty - Antwoord
die Variante mit slim case ist noch nicht berücksichtigt
Ansonsten: super Anleitung
W. Koch - Antwoord
Hat prima funktioniert dank einfacher Anleitung und einfacher Bauweise.
Christian Heider - Antwoord
Geschafft! - Schritt 4 war beim Slim Case nicht so einfach, aber nach ein paar Minuten hatte ich es raus. Ich frage mich bloss, was ich nun mit der alten Kamera mache..? Kann man die zurückschicken? Gibt es dazu irgendwelche Infos? Danke für die Anleitung und allfällige Infos bezüglich “Zukunft der alten Kamera” ;-) !
Claudia Serena Herrmann - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 97
Altijd: 122,679
