Inleiding
Vervang de schermmodule van je Fairphone 2.
Wat je nodig hebt
Kies een hoek van de behuizing en duw de nagel van je duim tussen de twee delen.
Trek het achterste deel van de behuizing omhoog om de kleine snap fit-verbindingen van elkaar te scheiden.
Verwijder het achterste deel van de behuizing.
Duw de batterij richting de bovenkant van de telefoon.
Trek de batterij weg uit de telefoon.
It isn't necessary to remove the rim if all you are doing is changing the battery. That becomes necessary if you are to proceed farther into the phone.
It might be good to begin by saying switch the phone off. The Fairphone is for everybody and most will have no experience of disassembling electronic devices.
Als je de batterij uit je telefoon hebt verwijderd, kun je de schermmodule ontgrendelen.
Schuif de twee blauwe vergrendelingen naar de binnenkant.
Schuif de schermmodule in de richting van de onderkant van de telefoon.
Being technically nervous I couldn't do this. I didn't know how much pressure, pull or push was required.
After I'd watched the video my confidence increased!
It was a bit stiff and not so easy.
You don´t mention taking the rim off the display first. That stymied me completely. Do add that to your otherwise clear and helpful instructions. Best wishes - Walt Patterson
This guide is based on the old bumper made in one piece. We should update to the sandwich bumper with a top and bottom part.
I agree. Took a while to figure that one out!
Sorry, I can not slide away the display assembly to change the main camera module. The 2 blue switches seem to be locked. Cristiano, Italy
I replay to myself: I did it at last! ! But it was very, very, very, very hard!
Can’t get any movement at all on screen been trying for over an hour and others too ! there is no way to grip it as its so slippery have tried putting as much presure as possible on display by pushing far end of it with thin plastic implement and endless wiggling and pressing of every possible part of lower case no joy ! feels like its attached at mid sides. Elinor Rivers
try sliding along the display while applying some pressure two or three times. it worked really easily for me
I could slide the display case off very easily after watching the video, but when it came to doing the sequence in reverse I was fiddling about for ages trying to ‘slide’ it back on, until I realised this just wasn’t going to work and needed to click it back into place. Posting here in case this is helpful for others.
Impossible de déplacer l'écran vers le bas chez moi. Je n'ose pas forcer... c'est normal?
I can not slide the display assembly. Some help?
The display sits very tight.
So you need to gently apply a little force to slide it open the first time.
It is hard to get a good grip on the two parts for a successful "magic move".
Leider kann ich weder mit "little force" noch mit "much force" das Display nach der Entriegelung bewegen. Wer kann mit mehr Details helfen?
It did work for me. Make sure, you have unlocked the blue switches in step 3 (sorry, had to mention that). if you can't get a grip, you might try to lay a ruler or two credit cards on top of each other on a table that is tight at the wall,
- place the ruler/credit cards on the table and just attaching the wall
- place the PF2 with the display upside down on the table in front of the ruler/credit cards with the blue switches towards you and the headphone plug attaching the ruler/cards.
- then gently but with increasing force push your two thumbs towards the top of the main FP2 unit (or use more fingers to push both in the centre as well as on the two edges). make sure you push horizontally and that the ruler is not higher than the border of the display unit (1.5-2 mm).
(hope i could explain myself in and understandable way! ;-) )
Thank you a lot ! This worked for me.
Thanks, it worked for us as well.
deRahier -
great tip! Thanks so much
Really helped! This way finally worked for me. Thanks :)
thank you !!
Unglaublich fair, dass ich mich mit diesem Kack alleine beschäftige - wenn ich so weitermache, werde ich demnächst die Trümmer meines Fairphones wahrscheinlich durch Ungeschicklichkeit so beschädigen, dass es unbrauchbar ist!
Om je toestel weer in elkaar te zetten, volg je deze instructies in omgekeerde volgorde.
37 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Thomas Keulemans helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
7 opmerkingen
Bonjour ! Es-tu bien sûr d'avoir déplacé les deux languettes bleues vers l'intérieur pour libérer l'écran ? Si oui, n'hésite pas à appliquer une certaine force sur l'écran (appuyer et déplacer vers toi).
Keine chance das Display zu bewegen. Nach 1h versuchen und allen FP2 Tutorials Videos bin ich immer noch gleichweit. Definitiv Verbesserung würdig. Für weitere Tipps bin ich dankbar, wird es sonst wieder zurück senden :-(
Birgit, denke ich du wollst dieser Link: Fairphone 1 Display Assembly Replacement
Managed it eventually but the “sliding” bit is really not that easy.
