Ga door naar hoofdinhoud
Fairphone 2 Display Assembly Replacement
Wat je nodig hebt
  1. Fairphone 2 Display Assembly Replacement, Slim Case: stap 1, afbeelding 1 van 3 Fairphone 2 Display Assembly Replacement, Slim Case: stap 1, afbeelding 2 van 3 Fairphone 2 Display Assembly Replacement, Slim Case: stap 1, afbeelding 3 van 3
    • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
    • Pull up the back part of the slim case to separate the small snap fit connections.
    • Remove the back part of the slim case.
  2. Fairphone 2 Display Assembly Replacement: stap 2, afbeelding 1 van 3 Fairphone 2 Display Assembly Replacement: stap 2, afbeelding 2 van 3 Fairphone 2 Display Assembly Replacement: stap 2, afbeelding 3 van 3
    • Get in between the front part of the slim case and the phone's body with your thumb nail.
    • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
  3. Fairphone 2 Display Assembly Replacement: stap 3, afbeelding 1 van 1
    • Remove the front part of the slim case.
  4. Fairphone 2 Display Assembly Replacement, Battery: stap 4, afbeelding 1 van 3 Fairphone 2 Display Assembly Replacement, Battery: stap 4, afbeelding 2 van 3 Fairphone 2 Display Assembly Replacement, Battery: stap 4, afbeelding 3 van 3
    • Push the battery toward the top of the phone.
    • Pull the battery out away from the phone.
  5. Fairphone 2 Display Assembly Replacement, Display Assembly: stap 5, afbeelding 1 van 3 Fairphone 2 Display Assembly Replacement, Display Assembly: stap 5, afbeelding 2 van 3 Fairphone 2 Display Assembly Replacement, Display Assembly: stap 5, afbeelding 3 van 3
    • After taking out the battery you can unlock the display assembly.
    • Flip the two blue switches to the inner position.
    • Slide the display assembly towards the bottom of the phone.
    • Another possible way of sliding the display assembly open.
  6. Fairphone 2 Display Assembly Replacement: stap 7, afbeelding 1 van 1
    • Take off the display assembly.
Conclusie
37 andere personen hebben deze handleiding voltooid.
Tobias Isakeit
117.426 Reputatie
188 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.528 handleidingen geschreven
7 opmerkingen
Bonjour ! Es-tu bien sûr d'avoir déplacé les deux languettes bleues vers l'intérieur pour libérer l'écran ? Si oui, n'hésite pas à appliquer une certaine force sur l'écran (appuyer et déplacer vers toi).
Oriane Petit - Antwoord
Keine chance das Display zu bewegen. Nach 1h versuchen und allen FP2 Tutorials Videos bin ich immer noch gleichweit. Definitiv Verbesserung würdig. Für weitere Tipps bin ich dankbar, wird es sonst wieder zurück senden :-(
Christian Rapp - Antwoord
Ich habe keine blauen Schalter, ich rede vom FP 1U, ist das korrekt?
Birgit - Antwoord
FP 1U: Ich habe keine blauen Schalter.....
Birgit - Antwoord
The Display seem to be stuck completely, any tips on how to move it?
siohdk - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 23
Altijd: 17,433
