Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
Slide the back cover down and remove it from the phone.
Use a fingernail in this indentation to push the battery toward the top of the phone
Pull the battery out away from the phone.
Use your finger to slide the SIM card straight down out of its tray.
Remove the SIM card from your Fairphone.
If you have a microSD card, use your finger to slide it straight out of its slot.
Remove the microSD card from your phone.
Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
Use an opening pick to carefully pry the midframe away from the display assembly.
Start just below the volume rocker and work your way down toward the bottom of the phone, freeing the plastic clips along the side.
Carefully round the corner, separating the midframe from the display assembly.
Separate any remaining clips and remove the midframe from the phone.
Use the flat end of a spudger to disconnect the antenna cable connector.
Use the tip of a spudger to flip open the tab on the daughterboard data cable ZIF connector.
Use tweezers to pull the daughterboard data cable away from its socket.
Remove the following screws securing the Wi-Fi daughterboard to the display assembly:
Two 2.5 mm Phillips #000 screws
One 1.6 mm Phillips #000 screw
Use tweezers to gently pry the board up and remove it from the phone.
9 andere personen hebben deze handleiding voltooid.
