Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Deze stap is niet vertaald. Help het te vertalen
Use tweezers to remove the volume rocker and power buttons from the display assembly.
Use the flat end of a spudger to disconnect the antenna cable connector.
Use tweezers to remove the adhesive foam tape from the top of the digitizer cable ZIF socket.
Use the tip of a spudger to flip open the tab on the digitizer ZIF connector.
Use tweezers to pull the digitizer cable away from its socket on the motherboard.
Remove the three 2.5 mm Phillips #000 screws securing the motherboard to the display assembly.
Gently lift the top end of the motherboard up to expose the display data cable.
Use the tip of a spudger to disconnect the display data cable from the back of the motherboard.
3 andere personen hebben deze handleiding voltooid.
