Ga door naar hoofdinhoud
Fahrenheit FHT 125PRMR Power Cord Replacement
Wat je nodig hebt
  1. Fahrenheit FHT 125PRMR Power Cord Replacement, Power Cord: stap 1, afbeelding 1 van 1
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Power Cord Replacement: stap 2, afbeelding 1 van 1
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Power Cord Replacement: stap 3, afbeelding 1 van 2 Fahrenheit FHT 125PRMR Power Cord Replacement: stap 3, afbeelding 2 van 2
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Power Cord Replacement: stap 4, afbeelding 1 van 2 Fahrenheit FHT 125PRMR Power Cord Replacement: stap 4, afbeelding 2 van 2
    • Use the Phillips Head 1 screwdriver to remove the two screws on the back where the power cable exits the device.
    • Once the two screws are removed; simply lift the case up and off to have access to the power cable.
  5. Fahrenheit FHT 125PRMR Power Cord Replacement: stap 5, afbeelding 1 van 1
    • To remove the power cable, grab the clear plastic holding and the base of the power cable and pull apart.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Joshua Potts
265 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-2, Harley Fall 2016 Lid van IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Leden
4 handleidingen geschreven
3Gids Commentaar
Where do I find a new power cord? I've tried searching everywhere.
tmbrand04 - Antwoord
Where do you buy the power cord?
Dominique - Antwoord
probably available at electronic store
john john - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 2,578
