Inleiding
This will show how to replace the battery in your FLIR FX security camera.
Wat je nodig hebt
Next, take out the battery and the silver protector.
Disconnect the white battery connector with your hands or a spudger.
I found the battery online its 13 dollars. https://www.mouser.com/Search/m_ProductD...
Can also use the SeaLife DC2000 Pro DC2000 Camera battery, but will require some soldering to adapt the battery to the original connector.
4 andere personen hebben deze handleiding voltooid.
21 opmerkingen
Do you know where we can find replacement batteries that fit?
Also looking for a replacement. Have a failing pack that has bulged the case. Currently talking with support. G713140AJ does not seem to be sold anywhere.
So far it appears the battery was made specifically for FLIR. Their Tech support says they do not recognize the battery as a user replaceable item and recommends the unit be sent in for repair. Hopefully as time goes and more of these units fail the battery vendors on ebay and other places might begin to carry them. Until then this camera will be an expensive paper weight as it will not setup with its internal battery unplugged.
Interesting note, I took an xacto knife and carefully relieved the bulge in the battery. Some liquid came out and the battery went back to its normal size. I did plug it back in and believe it or not it actually worked. I dont trust it though as lithium Ion batteries have a tendency to catch on fire, I can just imagine what would happen to one that has been compromised.
I spent a number of weeks trying to locate this battery including emailing battery vendors that import into the US. I finally got frustrated and contacted FLIR. I spent an additional week with emails going back and forth, FLIR will not sell you the battery for this camera. You can send it in for repair (which is really not cost effective) and they will send you a replacement refurb. One other interesting fact is that FLIR is closing out this camera, it has been replaced with the FLIR Secure HD. Somehow I would bet they aren’t using the same battery, lol
It is very disappointing that Flir is not selling replacement batteries. I have multiple FX cameras with bulging batteries and they will not go into direct connect mode anymore to allow me to change the WiFi password. The new models do not have batteries and they cost more than the previous model. They have HDR support and 16 GB SD cards, but are less versatile since they are strictly indoor security cameras. Flir is still selling the old models. The warranty is only a year long and the battery started swelling shortly afterwards. I use to recommend the FlirFX cameras, but not anymore. There are other brands that cost less and have the same features with the exception of the RapidRecap, but there is very limited access to that feature with the free plan.
Ordering Ofeely 3.7v 1200mah 804040 Polymer Li Ion from Amazon - Dimensions are really close; Volts and amp hours are correct - We’ll see what happens.
what happened
Don”t waist anymore of your time or money on flir products. They have no support and never answer the phone
Don’t waist anymore of your time or money with Flir products. They have no support and never answer their phones
Wow, this camera is packed with electronics in every square inch. I have one myself and I just wanted to see what tit looked like inside. I have no battery issues, but I will not open it unless I have to. I tried looking all over the web for a teardown of this camera, and this seems to be the only source. I can see why opening it can be intimidating. On the other hand, does anyone know if a custom firmware has been made for this camera? I know this is a hardware site, and reverse engineering a custom firmware for this is WAY above my, or the average joe’s knowledge. But it would be nice to add FTP, SFTP, web portal,(not just smartphone app crap), I mean a REAL web portal to this device. But, who knows. In the future someone may do it.
I ended up taking the battery out completely, and now it works fine. Just as long as there is power. I have it in an external case, so even if it is unplugged, seems to come right back online when you plug it back in. Much better behaved than with a weak/degrading battery. I am still disappointed that Flir does not offer a replacement part for a basic battery. A poor 3rd year experience. I will not buy another Flir FX, unless that changes.
I used a utility knife (razor blade) which, because it is so thin, fits into the crack between the silver and black pieces (the side at the bottom of the REC button) and with a little twist the back just popped off. If the battery isn’t swollen and therefore isn’t putting outward pressure on the back housing piece you might need to work the blade around the perimeter of the seam. As an FYI, the batteries in the camera and the base are the same. My camera battery is shot (swollen and leaking) so I put the base battery in the camera, popped the camera back on and it appears to be working fine.
Jeff where did you find the batteries for it.
I have just instructed FLIR to return my Flir 30 scope back to me, so I can attempt to either repair or somehow get unit operational without paying their exorbitant $731.00 to replace the batteries on a unit that was barely more than $1500.00 to begin with. I found it incredible to withstand the very abusive (translate-unfair) pricing of a repair of a unit that may have had a total usage of no more than 1 hour since new. I finally decided to not let Flir have their way, and as such, instructed them to return the unit un-repaired and as sent in, It is sad but true, that the attitude of Flir was basucally we do not care, you are beyond our warranty coverage, thus grin and bear it. But I am neither willing to “grin” nor to “bear it”. I will seek for alternatives to Flir for our thermal diagnostics. It is such a shame, as a company that makes such a quality product, is unwilling to back it up once your Credit Card clears.
Non-replaceable battery = built to break. Planned and forced obsolescence. It is theft. Good people are trying to get the right to repair enshrined in law, but the oligarchs don't want it.
One important point, if you remove the back using this method you will break the 2 plastic standoffs that screws into the rear cover from the front of the camera. This is not to say that you won’t be able to put the rear back on, it also clips on the side. I just wanted to point this out is you ever plan on sending the camera into FLIR, its an automatic warranty void! Also, you cannot find a replacement battery on the market for this unit. You must use a 3 lead battery. One option you can do is remove the base and plug the usb power cable directly into the side of the unit. It will work this way but not have battery backup. One last comment FLIR WILL NOT sell you a replacement battery as they do not believe it is a user serviceable part so if you want it fixed you must send it in to FLIR.
Educated Consumer - Antwoord
Correct. You have to pop off the front bezel and unscrew the two screws that hold the back on. Opposite of what was written. Front bezel then back with screws. Not back and then screws.
Mark LaPlante - Antwoord
