Inleiding
Is your FAO Schwarz Apex 1 failing to take turns and drift correctly? This guide will show you how to replace a wheel on your Classic Racer and correct any unwanted device maneuvering caused by a faulty wheel. All this simple fix requires is a J1 screwdriver bit to remove and reinstall the screws holding the wheel on.
Wat je nodig hebt
Position device so that the wheels are on a firm surface .
Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
I have a question about this! I had one of these cars for my son and lost the remote so I ordered another one off ebay. The new one arrived damaged, with one of the rear wheels broken off. The black plastic part on the axle that the wheel screwed into was cracked. So I’m trying to figure out if there is a way to remove this black plastic part from the old car to put on the new one. Or if I can swap out the whole rear axle. I really am not too mechanically inclined, but I want my son to have his remote control car functioning again and I’m really trying to avoid purchasing a 3rd one. Thank you!
