Ga door naar hoofdinhoud
FAO Schwarz Apex 1 Remote Control Battery Replacement
Wat je nodig hebt
  1. FAO Schwarz Apex 1 Remote Control Battery Replacement, Remote Control Battery: stap 1, afbeelding 1 van 1
    • Remove the plastic battery cover to get at the battery compartment.
    • The cover can be removed by pressing down on the lever and sliding.
  2. FAO Schwarz Apex 1 Remote Control Battery Replacement: stap 2, afbeelding 1 van 3 FAO Schwarz Apex 1 Remote Control Battery Replacement: stap 2, afbeelding 2 van 3 FAO Schwarz Apex 1 Remote Control Battery Replacement: stap 2, afbeelding 3 van 3
    • Remove the dead battery, being careful not to damage the internal battery connectors.
    • The battery is a bit wedged in there, so you'll have to press hard to pop it out.
  3. FAO Schwarz Apex 1 Remote Control Battery Replacement: stap 3, afbeelding 1 van 3 FAO Schwarz Apex 1 Remote Control Battery Replacement: stap 3, afbeelding 2 van 3 FAO Schwarz Apex 1 Remote Control Battery Replacement: stap 3, afbeelding 3 van 3
    • Insert the new 6F22 9 volt battery.
    • Line up the positive icons on the battery with the positive icons in the battery compartment.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 21
Altijd: 498
