Ga door naar hoofdinhoud
FAO Schwarz Apex 1 Front Axle Replacement
Wat je nodig hebt
  1. FAO Schwarz Apex 1 Front Axle Replacement, Wheel: stap 1, afbeelding 1 van 3 FAO Schwarz Apex 1 Front Axle Replacement, Wheel: stap 1, afbeelding 2 van 3 FAO Schwarz Apex 1 Front Axle Replacement, Wheel: stap 1, afbeelding 3 van 3
    • Position device so that the wheels are on a firm surface .
    • Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
  2. FAO Schwarz Apex 1 Front Axle Replacement: stap 2, afbeelding 1 van 1
    • After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
  3. FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: stap 3, afbeelding 1 van 2 FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: stap 3, afbeelding 2 van 2
    • Position device upside down so that the screws on the plastic axle pieces can be removed.
    • Use J1 screwdriver bit to remove two 10 mm screws to remove the plastic axle pieces to make access to the telescopic piston easier.
  4. FAO Schwarz Apex 1 Front Axle Replacement: stap 4, afbeelding 1 van 1
    • Secure a firm grip on the spring and telescopic piston.
    • Pull telescopic piston holding the spring off the device (this may be difficult).
  5. FAO Schwarz Apex 1 Front Axle Replacement: stap 5, afbeelding 1 van 1
    • Using a tool such as a spudger, gradually maneuver spring off of telescopic piston.
  6. FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: stap 6, afbeelding 1 van 3 FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: stap 6, afbeelding 2 van 3 FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: stap 6, afbeelding 3 van 3
    • Carefully turn the vehicle over so that the bottom side is facing upward.
    • Using a J1 Screwdriver bit, remove the two 10 mm screws that secure the wheel bearing.
    • Pull the plastic piece that secures the wheel bearing off of the axle.
  7. FAO Schwarz Apex 1 Front Axle Replacement: stap 7, afbeelding 1 van 2 FAO Schwarz Apex 1 Front Axle Replacement: stap 7, afbeelding 2 van 2
    • Position the axle entirely upright before lifting away from the vehicle.
Conclusie
Carsyn Bernhardt
88 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 254
