Ga door naar hoofdinhoud
Ezonics EZ-307 Main Board and USB Cable Replacement
Wat je nodig hebt
  1. Ezonics EZ-307 Main Board and USB Cable  Replacement, Get Tools: stap 1, afbeelding 1 van 1
    • A Phillips Head Size Zero Screw Driver
  2. Ezonics EZ-307 Main Board and USB Cable  Replacement, Detach the Base: stap 2, afbeelding 1 van 1
    • Using a Phillips-head screwdriver, remove each of the 3 screws from the underside of the camera head.
  3. Ezonics EZ-307 Main Board and USB Cable  Replacement, Set Aside the Base: stap 3, afbeelding 1 van 1
    • Gently pull back the base and set it aside.
    • Be careful not to pull out the USB cable attachment when taking off the base
  4. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove USB Connector: stap 4, afbeelding 1 van 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove USB Connector: stap 4, afbeelding 2 van 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove USB Connector: stap 4, afbeelding 3 van 3
    • Gently remove the white connector with the red, green, white & black cord with your fingers. This connector is the end of the USB cable.
  5. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Top Lens Casing: stap 5, afbeelding 1 van 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Top Lens Casing: stap 5, afbeelding 2 van 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Top Lens Casing: stap 5, afbeelding 3 van 3
    • Press tab on inside of device to release silver ring.
    • Gently remove top (silver) ring of lens casing with your fingers.
  6. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Inner Lens Casing: stap 6, afbeelding 1 van 2 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove Inner Lens Casing: stap 6, afbeelding 2 van 2
    • Gently remove inner casing of the lens (silver with a black ring).
    • Be careful not to break the small notch at the top, which holds the inner casing in place.
  7. Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove the Inner Ring: stap 7, afbeelding 1 van 2 Ezonics EZ-307 Main Board and USB Cable  Replacement, Remove the Inner Ring: stap 7, afbeelding 2 van 2
    • Remove the small, black, ridged inner ring around the lens with your fingers.
  8. Ezonics EZ-307 Main Board and USB Cable  Replacement, Unscrew the Lens: stap 8, afbeelding 1 van 2 Ezonics EZ-307 Main Board and USB Cable  Replacement, Unscrew the Lens: stap 8, afbeelding 2 van 2
    • Unscrew the lens counterclockwise with your fingers.
  9. Ezonics EZ-307 Main Board and USB Cable  Replacement, Carefully Remove Board From Outer Casing: stap 9, afbeelding 1 van 2 Ezonics EZ-307 Main Board and USB Cable  Replacement, Carefully Remove Board From Outer Casing: stap 9, afbeelding 2 van 2
    • Turn the hollow outer casing so that you can see inside of it.
    • Gently pull out main board with fingers.
  10. Ezonics EZ-307 Main Board and USB Cable  Replacement, A New Board: stap 10, afbeelding 1 van 2 Ezonics EZ-307 Main Board and USB Cable  Replacement, A New Board: stap 10, afbeelding 2 van 2
    • Insert your new board into the outer casing. Be sure that it rests firmly between the sets of rails on either side.
  11. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassembly of Lens: stap 11, afbeelding 1 van 2 Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassembly of Lens: stap 11, afbeelding 2 van 2
    • Twist the lens piece in clockwise and then insert black ring around the lens.
  12. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Lens: stap 12, afbeelding 1 van 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Lens: stap 12, afbeelding 2 van 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Lens: stap 12, afbeelding 3 van 3
    • Line up notch on inner lens casing (silver with black ring) with notch on body of camera. Gently push it into place, being sure not to break the notch.
    • Insert the silver ring. You should hear it click into place.
  13. Ezonics EZ-307 Main Board and USB Cable  Replacement, Insert the USB Cord: stap 13, afbeelding 1 van 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Insert the USB Cord: stap 13, afbeelding 2 van 3 Ezonics EZ-307 Main Board and USB Cable  Replacement, Insert the USB Cord: stap 13, afbeelding 3 van 3
    • Hold the camera in one hand with the hollow side facing up.
    • Hold the USB cable in your other hand with the four small holes facing up.
    • Plug the USB cable into the port.
  14. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Base of the Camera: stap 14, afbeelding 1 van 1
    • Lay the USB cord in the notch at the base of the camera bottom.
    • Place the bottom back onto the camera top.
  15. Ezonics EZ-307 Main Board and USB Cable  Replacement, Reassemble the Base of the Camera: stap 15, afbeelding 1 van 1
    • Line up the base of the camera with the screw holes.
    • Use a Phillips-head screwdriver to twist the three screws back into place.
Conclusie
Lyndsi
7 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-5, Mccook Fall 2014 Lid van Ohio State, Team 1-5, Mccook Fall 2014
OSU-MCCOOK-F14S1G5
4 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 8
Altijd: 582
