Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Seagate Expansion te repareren, gebruik onze reparatiehandleidingen.
  1. Expansion Teardown, Open the cover: stap 1, afbeelding 1 van 1
    • Using a flat head screwdriver or plastic tool
  2. Expansion Teardown: stap 2, afbeelding 1 van 1
    • Remove the cover
  3. Expansion Teardown: stap 3, afbeelding 1 van 1
    • Remove the drive from the case
  4. Expansion Teardown: stap 4, afbeelding 1 van 1
    • Peel back the shielding
  5. Expansion Teardown: stap 5, afbeelding 1 van 1
    • Remove the Screw with the #02 screw driver
  6. Expansion Teardown: stap 6, afbeelding 1 van 2 Expansion Teardown: stap 6, afbeelding 2 van 2
    • Separate the adapter form the sata port
Dan
5.156 Reputatie
9 handleidingen geschreven
3Gids Commentaar
Hello,
I’d like to know if it’s possible to swap in another bigger NAS drive, as I keep my hard drive connected and it might be more durable.
Thank you !
Léana Jiang - Antwoord Deel
This does appear to be a semi-destructive method. In the picture under step 2, you can see the series of plastic brackets on the cover are snapped. See my pictures here
I had difficulty finding a spot to pry up from. There are 4 lips around the cover that should make it easier. See pics.
Derick Roy - Antwoord Deel
Answering a previous comment: yes, it is possible to replace the drive for one of different size. I replaced on of 3TB for one with 4TB and it is working perfectly.
Giovanni Bassi - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 103
Altijd: 6,126
