Inleiding
This guide walks you through the replacement of the Eureka SuctionSeal 2.0 Pet Brush Roll Belt. A damaged brush roll is a common occurrence and can create several problems, making this a useful troubleshooting guide.
Wat je nodig hebt
Place the device upright with the brush roller closest to you.
Pull up on the latch at the top of the dust cup.
Tilt the top of the dust cup forward and pull towards yourself, removing the container from the device.
Locate the gray exhaust filter cover at the top of the vacuum's base.
Grip the two tabs in the middle of the filter cover and rotate counter-clockwise.
Lift the cover away from the vacuum.
Locate the belt latch assembly. It will be on your right when the brush roll is facing you.
Remove the two 20mm screws using a JIS 1 screwdriver.
Grab the brush roll on both ends.
Lift up on the right side of the brush roll.
Lift up on the left side of the brush roll, completely removing it from its frame.
Separate the brush roll from the belt and remove the brush roll from the vacuum.
Rotate the belt until the front is above the motor shaft.
Twist the belt away from you, allowing the narrow side of the belt to slip between the motor shaft and the vertical rod.
Separate the belt from the motor shaft.
4 opmerkingen
Thank you so much for this guide! I actually just needed to complete steps 4-10 for the vaccum and everything worked. No need to take the upper half off any more and turns out I didn’t have to replace the belt. I believe there was just a bunch of thick cat hair caught in between the latch assembly and the brush. Thanks again for your time and effort in putting together this guide!
Where do you get new belt & belt latch assembly?
The one I have seems to have sustained a slight heated friction deformity due to the belt not seated correctly...🤷🏼♂️
Thanks it was a great tutorial. I see now why people threw it away no time to read thru steps and take the time easier to put on side of road and buy a new one.it didn't need a belt just needed to get rope tied around brush off and then it freed up the brush .I got a perfectly new clean vacuum free because they rather spend money than take the time.thanks again
