Inleiding
Sometimes, the belt in the vacuum can go bad or even just come loose. In order to properly maintain your vacuum, it’s important to know how to replace the belt. This guide covers the necessary steps for a successful replacement. Make sure your vacuum is off before attempting any replacements.
Wat je nodig hebt
Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
Pull the roller, motor, and belt out of the casing.
Separate the belt from both the roller and the motor.
