Inleiding
If the accessory holder is no longer able to hold the multiple tools associated with the vacuum, this guide outlines the its replacement.
Wat je nodig hebt
On the back of the vacuum, pull the handle connected to the hose away from the vacuum.
Using a T15 Torx Security Screwdriver, remove the screw on each side of the indention in which the hose normally rests.
Één andere persoon heeft deze handleiding voltooid.
