Ga door naar hoofdinhoud
Eureka AirSpeed Bagless Zuum Brush Roll Replacement
Wat je nodig hebt
  1. Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: stap 1, afbeelding 1 van 2 Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: stap 1, afbeelding 2 van 2
    • Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
    • Insure the vacuum is unplugged before starting the process of removing the brush roll.
  2. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove the four screws from each corner of the brush roll cover.
  3. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: stap 3, afbeelding 1 van 2 Eureka AirSpeed Bagless Zuum Brush Roll Replacement: stap 3, afbeelding 2 van 2
    • Remove the brush cover from the vacuum base, by pulling straight up.
  4. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: stap 4, afbeelding 1 van 1
    • Firmly press upwards from below the brush roll on the side opposite the belt.
  5. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: stap 5, afbeelding 1 van 1
    • After one end is displaced, remove the other side by pressing firmly upwards from below the the brush roll.
  6. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: stap 6, afbeelding 1 van 1
    • Once the brush roll is displaced from the base, detach the belt from the brush roll in order to clean the brush roll.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Celina Burchett
1.122 Reputatie
8 handleidingen geschreven
Clemson, Team 2-2, Benson Fall 2014 Lid van Clemson, Team 2-2, Benson Fall 2014
CLEM-BENSON-F14S2G2
4 Leden
18 handleidingen geschreven
Één opmerking
Brush roll replacement is a no brainer. It is the brush roll assembly that turns the brush that I need to fix. Cannot determine what tool to use as it doesn't come off using a regular screwdriver and eureka won't tell me what to ese.
Tami Jones - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 18
Altijd: 12,024
