Inleiding
Replace the small wheel or 'roller' on the bottom of the Eureka.
Onderdelen
Geen onderdelen nodig.
  1. Press the black separator switch and lightly pull the bottom half away from the top. Press the black separator switch and lightly pull the bottom half away from the top.
    • Press the black separator switch and lightly pull the bottom half away from the top.
  2. Remove the vacuum head from the lower half of the body. Remove the vacuum head from the lower half of the body.
    • Remove the vacuum head from the lower half of the body.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  4. Turn the vacuum head wheels up and remove all seven 13.9mm screws from the bottom using a #2 Phillips head screwdriver. Separate the top and bottom of the vacuum head. Set the top aside. Separate the top and bottom of the vacuum head. Set the top aside.
    • Turn the vacuum head wheels up and remove all seven 13.9mm screws from the bottom using a #2 Phillips head screwdriver.
    • Separate the top and bottom of the vacuum head. Set the top aside.
  5. Turn the vacuum head's bottom over so that the inside of the head is facing up. Using a Phillips #00 screwdriver, press down on metal bar of the roller on one side until it releases from the housing.
    • Turn the vacuum head's bottom over so that the inside of the head is facing up.
    • Using a Phillips #00 screwdriver, press down on metal bar of the roller on one side until it releases from the housing.
      • Turn the vacuum head's bottom over and pull at the roller and bar until they are completely out of the housing.
  6. Press the new bar and roller into place.
    • Press the new bar and roller into place.
      • Replace the screws.
Eindstreep
Jennifer Sheils
4 Reputatie
2 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 122
