Inleiding
Having issues with your Robovac and suspect it may be the power source. Use this guide to replace your battery and restore your Robovac 11s to full performance. This is a short guide that should take no longer than 20 minutes to replace the component. Batteries have a tendency to diminish over time. This replacement guide should help you get your device back up and running.
Wat je nodig hebt
Flip Robocav Over on the soft side
Turn the power switch of the Eufy Robovac 11s to the off position
To reassemble your device, follow these instructions in reverse order. If device still fails to operate complete the guide once again and make sure battery is full connected and charged.
